DRAW Reference Manual
Dimensioning : Summary of Commands : Creating Angular Dimensions . . .
specify the Design item which will be referenced for an Angular Dimension - sets DDNM
FROM DIR option
creates a Dimension start point with the direction set as the p-point specified - sets DDNM & PPDI, or if direction specified - sets DIR. options: PA, PL, PH, PT, PPoint, IDP, N, S, D, E, W, X, Y, X, HH, HT
TO DIR option
creates subsequent dimension Point with direction set as p-point specified - sets DDNM & PPDI, or if direction specified - sets DIR
sets the dimension line position as an offset radius from the first Dimension Point - sets DOFF
changes rotational sense of angular dimensions
