DRAW Reference Manual
Dimensioning
: Suppressing the Display of Dimension and Projection Lines
The display of either the dimension or projection lines of a Linear or Angular Dimension may be suppressed using the DLFG attribute of the LDIM:
DLFG PROJ
causes only the projection lines of a Dimension to be drawn. The setting of the LCHAIN attribute is ignored in this case - all dimensions are treated as chained. This enables coordinate dimensions to be output - with the coordinate reported in the projection-line text.
DLFG DIM
causes only the dimension lines of a Dimension to be drawn. The default setting, causes both dimension- and projection lines to be drawn:
DLFG ALL
