DRAW Reference Manual
Dimensioning
Radial Dimensions
: Creating Radial Dimensions using the Cursor
The creation methods given here are applicable to RDIMs and PDIMs (Pitch Circle Dimensions). Refer to
for further information.
In addition to the basic creation method given in
, some style attributes may be defined by cursor interaction. Having created the RDIM/PDIM and defined its position,
DIM @
will cause both dimension angle DDEG and text radius DTRAD to be defined in one go. (The dimension text origin will be at the cursor crosshair position.) It will not modify DTOF.
