DRAW Reference Manual
Dimensioning : Dimension Element Types
Linear Dimension (LDIM) elements (refer to Linear Dimensions for further information) exist for each linear dimension that appears on a drawing. LDIM elements own Dimension Point elements, which specify the points between which dimensions are drawn. Two other types of linear dimension are:
Radial Dimension (RDIM) elements (refer to Radial Dimensions for further information) exist for each radial dimension that appears on a drawing, being defined by a database element and an attribute (e.g. DIAM of a CYLI).
Pitch Circle Dimension (PDIM) elements (refer to Pitch Circle Dimensions for further information) exist for each pitch circle dimension that appears on a drawing. PDIM elements own Dimension Point elements, which specify the points between which dimensions are drawn. The graphics for a PDIM are similar to those for an RDIM.
Angular Dimension (ADIM) elements (refer to Angular Dimensions for further information) exist for each angular dimension that appears on a drawing. ADIM elements own Dimension Direction elements, which specify the end points of the dimension arc and its origin.
When a Pipe element is dimensioned directly, the Pipe origin is assumed to be the position of the HEAD of the first Branch visible in the VIEW region, if any. If no Branch HEADs are visible in the VIEW region, then the position of the HEAD of the first Branch is used.
