Data Model
Elements in Piping Major Items Category
: Pipe Hanger Element (HANGER)
Piping Major Items Element
Primary Element
Description:
The HANGER is a two-ended entity which is routed between a BRANCH and supporting steelwork. It is analogous in many respects to the BRANCH element and can own Components routed between a Head and Tail. The Head or Tail can be connected to a piping attachment point (ATTA) or positioned specifically, for example: on a supporting member. Its attributes can be classified as follows:
Functional and Information attributes for the complete HANGAR (described here).
Head and Tail attributes (already described).
Attributes:
Name
Name of the element
Description
Description of the element
Function
Function
Purpose
Description code word
Number
Number
Area
Area
Hspec
Hanger specification
Hsrod
Headrod specification
Htype
Hanger type
Nload
Nominal load
Lhead
Logical head flag
Ltail
Logical tail flag
Hposition
Head position
Tposition
Tail position
Hdirection
Head direction
Tdirection
Tail direction
Href
Head reference
Tref
Tail reference
Hconnect
Head connection type
Tconnect
Tail connection type
Hbore
Head bore
Tbore
Tail bore
Built
Built/Unbuilt flag
Orrf
Invfarray
Array of Inventory Items
Legal Owners:
Restraint Element (RESTRAINT)
Legal Members:
Beam Bolting Attachment Element (BBOLT)
Beam Welding Attachment Element (BWLD)
Clevis Element (CLEVIS)
Eyenut Element (EYENUT)
Eye Rod Element (EYRD)
Hanger Element (HELEMENT)
Hanger Nut Element (HNUT)
Hanger Pin Element (HPIN)
Hanger Rod Element (HROD)
Pipe Clamp Element (PCLAMP)
Pipe Clip Element (PCLIP)
Pipe Lug Element (PLUG)
PCLA Overstrap Element (POST)
Rod Coupling Element (RCPL)
Steel Clamp Element (SCLAMP)
Shoe Element (SHOE)
Steel Lug Attachment Element (SLUG)
Snubber Element (SNUB)
SCLA Overstrap Element (SOST)
Spacer Element (SPACER)
Steel Section Element (STLS)
Sway Brace Element (SWBR)
Turnbuckle Element (TRNB)
Trunnion Element (TRNN)
U Bolt Element (UBOLT)
Variable Effort Spring Hanger Element (VSPR)
Washer Element (WASH)
Wear Pad Element (WPAD)
