Data Model
: Elements in Piping Major Items Category
Branch Element (BRANCH)
Piping Major Items Element
Primary Element
Description:
The BRANCH is the key element for all routed piping in the Design model. It represents a two-ended entity whose route is defined by its Head, Tail and the sequence of Components (Members) between. A BRANCH Head or Tail may be connected to NOZZLEs, multi-way Components such as TEEs, or other BRANCH Heads or Tails. Alternatively, a Head or Tail may be positioned explicitly in space. (All the commands which control the Head and Tail attributes are described in
Spooler Database
.) The remaining BRANCH attributes are for:
Functional Use
Information storage
Attributes:
Name
Name of the element
Description
Description of the element
Function
Function
Purpose
Description code word
Built
Built/Unbuilt flag
Shop
Shop/Site flag
Isohidden
Isohidden flag
Hposition
Head position
Tposition
Tail position
Hdirection
Head direction
Tdirection
Tail direction
Href
Head reference
Tref
Tail reference
Lhead
Logical head flag
Ltail
Logical tail flag
Hbore
Head bore
Tbore
Tail bore
Hconnect
Head connection type
Tconnect
Tail connection type
Detail
Detail flag
Lstressed
Stress flag
Linetype
Line type
Erection
Erection class
Temperature
Temperature
Pressure
Pressure
TPressure
TestPressure
Flowdirection
Flow direction
Hstube
Head tube specification
Ccentre
Cost centre
Cclass
Cost class
Safclass
Safety class
Matref
Material reference
Fluref
Fluid reference
Casref
Case reference
Pspec
Pipe specification
Ispec
Insulation spec reference
Tspec
Tracing spec reference
Duty
Duty
Dscode
Design code
Ptspec
Paint specification
Inschedule
Inspection schedule
Splh
Old spooler head tube spool number
Hdmtype
ISODRAFT Reference Dimension attribute
Hdmfarray
Tdmtype
Tdmfarray
Lissue
True if drawing has been issued
Wmaximum
Maximum weld number in current spool drawing
Pmaximum
Maximum part number in current spool drawing
Ptnhead
Old spooler head tube part number
Smaximum
Maximum spool number in current spool drawing
Jmaximum
Maximum joint number in current spool drawing
Mtohead
Material list control for head tube
Ptnbarray
Old spooler bolt part number
Drrf
Old spooler drawing reference
Spsp
Old spooler spool prefix
Jnumber
Old spooler joint number
Joiprefix
Old spooler joint number prefix
Orrf
BendMacReference
Bending Machine reference
Inco
Array of integers for ROUTER internal points
PLANU
Planning Unit
Bstatus
Branch Status code (Router)
Hwrf
Head Working Point (Router)
Twrf
Tail Working Point (Router)
Brlock
Branch Positioning Status code (Router)
Rlstored
Array of ROUTER saved rules
Tsfbreak
Spooling marker for leave tube
Deldsg
Delivery Designation flag
Mdsysf
Reference Array of Model and Design Elements
Inprtref
Inside paint reference
Ouprtref
Outside paint reference
Sloreference
Pipe slope reference
Legal Owners:
HVAC Element (HVAC)
Pipe Element (PIPE)
Legal Members:
Air Handling Unit Element (AHU)
Attachment Point Element (ATTACHMENT)
Battery Element (BATTERY)
Bend Element (BEND)
Branch Connector Element (BRCO)
Cap Element (CAP)
Closure Element (CLOSURE)
Coupling Element (COUPLING)
Cowl Element (COWL)
Cross Element (CROSS)
Damper Element (DAMPER)
Ducting Element (DUCTING)
Elbow Element (ELBOW)
Blind Flange Element (FBLIND)
Filter Element (FILTER)
Flange Element (FLANGE)
Flexible Element (FLEXIBLE)
Fixed Length Tube Element (FTUBE)
Gasket Element (GASKET)
Grille Element (GRILLE)
Access Panel Element (HACC)
Fan Element (HFAN)
Saddle Element (HSADDLE)
Internal Damper Element (IDAM)
Instrument Element (INSTRUMENT)
Lap-joint Stub End Element (LJSE)
Mesh Element (MESH)
Offset Element (OFST)
Olet Element (OLET)
Piping Component Element (PCOMPONENT)
Plate Element (PLATE)
Plenum Element (PLENUM)
Reducer Element (REDUCER)
Standard Hook-up Element (SHU)
Silencer Element (SILENCER)
Skirt Element (SKIR)
Splitter Element (SPLR)
Stiffener Element (STIFFENER)
Straight Element (STRT)
Taper Element (TAPER)
Tee Element (TEE)
Threeway Element (THREEWAY)
Test Point Element (TP)
Trap Element (TRAP)
Transformation Piece Element (TRNS)
Union Element (UNION)
Valve Element (VALVE)
Vent Element (VENT)
Four Way Valve Element (VFWAY)
Three Way Valve Element (VTWAY)
Weld Element (WELD)
