Laser : Tools
A temporary pipe aid can be introduced into the 3D view. On the Laser tab, in the Tools group, click Fit Aid to Pipe, a point should be picked on the surface of the pipe data. The process will determine the best fit cylinder diameter and also its centre line direction.
On the Laser tab, in the Tools group, click Fit Aid to Pipe to allow the AID graphic representation of the pipe to be extended or trimmed back. This is achieved by a two step process of selecting the AID graphics and then selecting a point of laser data, the result is the AID is extended in the direction to coincide with the point picked.
Delete Aid Pipe - Select within the 3D view individual AID pipes to delete.
Delete All Aid Pipes - Deletes all AID pipes within the display
If the user has created design points from the AID graphics for a pipe, the user needs to be able to manage this data. On the Laser tab, in the Tools group, click D-Points to display the D-Point Information window.
The D-Point Information window displays the list of design points associated with a selected XGEOM element and the design points will be displayed as AID graphic showing the orientation and bore of the design point. The selected design points have additional design point labelled with the name or database reference attribute in the 3D view. If the user right clicks on a design point, the following right click menu options are displayed:
