Data Check : Surface Treatment : Surface Treatment Report
With the required element as the CE, on the Tools tab, in Tools group, click Surface Treatment, select Treatment Report from the drop-down list to display the Surface Treatment – Report window.
When the Surface Treatment - Report window is loaded, the CE is set automatically. Navigating to another element within the Model Explorer. Click CE to set that as the current CE for the Surface Treatment - Report window.
Click Calculate to calculate the inside and outside surface area for each component owned by the CE and displays the results in the Selected elements grid.
Once the user has selected items from the Selected elements grid, right-click in the grid to display a pop-up menu which has the following options:
