On the Tools tab, in the
Tools group, click
Surface Treatment, select
Assign Surface Treatment from the drop-down list to display the
Surface Treatment – Assignment window.
The Scope definition area of the window assists in selecting database elements to assign surface treatment to and displays them in the
Selected elements area of the window in a grid.
The Scope definition drop-down options list can be used to filter by a particular element type, For example, if PIPE is selected and a ZONE containing only EQUI elements is selected, the
Selected elements grid does not display any results. Similarly, if EQUI is selected and a ZONE containing only EQUI elements is selected, only the EQUI elements are displayed in the grid. However, if ALL is selected the Zone containing only EQUI elements displays the NOZZ elements as well.
The radio buttons in the Scope definition area have the following functionality:
Click Select or
Add Item to populate the
Selected elements grid with the elements based on the chosen method and criteria.
The Select option clears the grid of any existing elements and adds the selected items.
The Add Item option appends the selected items to the items already displayed in the grid.
Once the Selected elements grid is populated, elements from the grid must be selected to apply the surface treatment. Selections can be made from the grid using standard Windows selection methods.
The database MASTER/PIPECATA contains four predefined
Table groups (Selection Tables) which can be selected using the
Table group drop-down list.
The Table Group drop-down list has the following options:
Each Table Group option has a number of specification based table items which are selected from the
Table item drop-down list:
When a Table item has been selected, the
Specification if applicable,
Symbol code and
Punch code text boxes are automatically filled with the relevant information.
Click Apply and a warning message is displayed.
Click OK assigns the surface treatment to the specified items and removes them from the
Selected elements grid.
Viewing the Attributes (on the
Home tab, in the
Common group, click
Attributes list) of the processed elements it can be seen that the
Inprtref attribute has been displayed accordingly.
Once the user has selected items from the Selected elements grid, right-click in the grid item displays a pop-up menu which has the following options:
The Surface Treatment - Selection window contains
Table group and
Table item drop-down list, whose functionality is the same as previously described for the
Surface Treatment – Assignment window. However, selecting a
Table group and
Table item displays details and coatings of the surface treatment.
Click Inside,
Outside or
Both to update the selected items in the grid with the details from the selected surface treatment.
Click Clear to clear the details on the window.
Click Apply on the
Surface Treatment – Assignment window to update the attributes on the selected items after the grid is updated.
