The databases listed in the In Database combo-box are those that are available to the user and the combo-box automatically updates if the database item exists in any of those databases. Similarly, if the user changes the database type in the combo-box then the database item currently displayed is checked, and if not found in that database, the ceiling of the search scope is reset to world.
To set the search scope for Volumetric Searching, select In Volume check box to activate the
Of Element and
Explicit Volume search scope approaches.
With the Of Element check box selected, enter a valid model element for the scope of the search in the adjacent combo-box. Alternatively, click
CE to enter the current element in the combo-box. The elements found resides within the volume of the specified model element. A
Clear History option is available from the drop-down list.
With the Explicit Volume check box selected, the user can specify the opposite 2 corners of a 3D box in which to conduct a search by setting the appropriate coordinates in the
X,
Y and
Z boxes.
The Wholly within and
Wholly & Partially within options, which are applicable to both volumetric search approaches, allow the user to specify whether the found elements exist completely or partially within the specified volume.
Select the Modified drop-down list to display a specific time or session of modification, the user can leave it Off if not required. Checking the
Show Modified Date on Output check box, displays the modified date on the
Search Results window.
