Design Aids : 3D Construction Aids : Aid Copy/Move Mirror
The Aid Copy Mirror window allows the user to create a copy of aid constructs, singly or in groups and mirror the copy in a specified plane.
From the 3D Aid Constructs window select Create > Copy > Mirror to display the Aid Copy Mirror window.
Click Pick to start picking a new group.
Click Clear to clear the selected pick.
Defines the reflection plane in terms of its direction (normal to its surface) and a position through which it passes. Either enter the Position (East, North, Up) coordinates and if required, select one or all of the Lock check boxes to fix the current co ordinate along the axis) and Direction explicitly, or derive them from existing design items as follows:
Pick position of mirror plane allows the user to derive the Position (but not the Direction), pick an item in the 3D View.
Pick mirror plane allows the user to derive both the Position and Direction, pick an item in the 3D View.
E/N/U Direction to use a direction component of the current element
The With Respect To (wrt) text box allows the selection of co-ordinates with respect to any design element.
Click Apply to create the copy, or executes the move, but confirmation is required to retain the change. Click Dismiss to cancel the copy or the move.
