Displays the Aid Constructors window.
Displays the Save Construction Graphics window, allows the user to save all the aids in a named file.
Displays the Load Construction Graphics window, allows the user to load a saved file.
Closes the 3D Aid Constructs window.
Select Settings > Repeat to allow the user to continue creating instances of the same construction aid until the user presses Esc on the keyboard.
Displays the Working Points Size window, allows the user to display the size of the work points.
Displays the Aid Copy/Move Offset window, allows the user to create multiple copies and move each by a specified offset distance.
Displays the Aid Copy/Move Rotate window, allows the user to create multiple copies and rotate each through a specified angle about a given axis.
Displays the Aid Copy/Move Mirror window, allows the user to create a single copy and mirror it in a specified reflection plane.
The options available include normal geometric constructions, deriving the 2D geometry from modelling elements and explicit definitions. The Toolbar option displays the Circles window, which displays a set of icons that provide shortcuts to the available construction methods. The user can position the cursor over any icon to view a tooltip summarising its function.
The options available include normal geometric constructions, deriving the 2D geometry from modelling elements and explicit definitions. The Toolbar option displays the Lines window, which displays a set of icons that provide shortcuts to the available construction methods. The user can position the cursor over any icon to view a tooltip summarising its function.
The options available include normal geometric constructions, deriving the 2D geometry from modelling elements and explicit definitions. The Toolbar option displays the Work Point window, which displays a set of icons that provide shortcuts to the available construction methods. The user can position the cursor over any icon to view a tooltip summarising its function.
The options available include normal geometric constructions, deriving the 2D geometry from modelling elements and explicit definitions. The Toolbar option displays the Plane window, which displays a set of icons that provide shortcuts to the available construction methods. The user can position the cursor over any icon to view a tooltip summarising its function.
The options available include normal geometric constructions, deriving the 2D geometry from modelling elements and explicit definitions. The Toolbar option displays the Grids window, which displays a set of icons that provide shortcuts to the available construction methods. The user can position the cursor over any icon to view a tooltip summarising its function.
Displays the Aid Copy/Move Offset window, allows the user to move the aid by a specified offset distance.
Displays the Aid Copy/Move Rotate window, allows the user to rotate the aid through a specified angle about a given axis.
Displays the Aid Copy/Move Mirror window, allows the user to mirror the aid in a specified reflection plane.
The Toolbar option displays a set of icons that provide shortcuts to the available construction methods. The user can position the cursor over any icon to view a tooltip summarising its function.
