Design Aids : 3D Construction Aids : Working Points Size
The Working Points Size window allows the user to set the size of the working points. From the 3D Aid Constructs window select Settings > Size to display the Working Points Size window.
Click to select options New or Defined to allow the user to apply the value to the new working points or use the existing defined values.
Click OK to accept the changes or click Cancel to discard any changes.
