Design Aids : Move : Through
The user must first select the element to be moved in the Model Explorer or in the 3D graphical view. On the Home tab, in the Common group, click Position Relatively By, select Move from the drop-down list to display the Move window with the Through tab displayed.
The Parameters pane displays the following options:
From the Origin drop-down menu select Origin or the P-Point that is used as the reference point for the move.
Enter the Direction of movement and an element in the WRT field that defines the frame of reference for the direction. The user can select WRT from the following options:
The Target pane displays the following options:
Select Plane Through Target check box to allow the current element to be moved so that its origin moves to the intersection of the direction of movement and the reference plane. The direction of the plane normal is entered into the Plane text field. The Plane must not be parallel to the direction of movement. The position of the plane is defined by the selected Through element or position.
The type of target item is specified by the Through option. The target can be a geometry element or a position. The following options are available:
Click Pick Target Element icon and pick a target element on the 3D view, to populate the Name field. Click Apply.
Click Pick Target Position icon and pick a target position on the 3D view for graphical highlight of the selected position. Click Apply.
