Design Aids : Move
On the Home tab, in the Common group, click Position Relatively By, select Move from the drop-down list to display the Move window.
The Move window allows the user to move the Current Element (CE) in a given direction. CE can be moved by a given distance in that direction or it can be moved to a position relative to another element or relative to a plane through a given position.
In the Move window the Equipment To Move pane allows the user to click CE to select an element to move.
