The origin of the CE is moved In front of the surface of the reference element. There must be a plan component in the direction.
The origin of the CE is moved Behind the surface of the reference element. There must be a plan component in the direction.
The origin of the CE is moved Ontop the surface of the reference element. There must be an elevation component in the direction.
The origin of the CE is moved Under the surface of the reference element. There must be an elevation component in the direction.
The origin of the CE is moved until it is the specified distance From the origin of the reference element.
The origin of the CE is moved until it is the specified distance Towards the origin of the reference element.
Click Pick Target Element icon and pick a target element on the 3D view, to populate the Name field.
Click Pick Target Position icon and pick a target position on the 3D view for graphical highlight of the selected position.
