On the Project tab, the
Help options is displayed by default:
Under Support select
AVEVA Design Help to display the
User Guide AVEVA Plant window with the
Contents tab selected. The user can navigate to the required topic from the contents list. The user can specify a keyword(s) and
Search for all instances of that keyword is used within the documentation suite. The user can add
Favourites to re-visit previous saved searches.
Contact AVEVA or
Check for Updates to display the
AVEVA Product Support web page. The user can access AVEVA contact details and check for the latest updates.
Click Additional Info to display the
Additional Information window which reports all the details related to all the version.dat files, which are located in the PMLLIB and PMLUI search paths.
Click Copy Info to copy the information to the clipboard and allows the user to paste the information into a file, which can then be saved.
Click Appware to scan all the application appware and to check if any have been changed. All changes are displayed in the
Appware Changes from Installed window.
