Common Functionality
Getting Started
: Modules
Modules
Design is divided into a number of functional modules which access the databases for a different purposes. To change to a different module, on the
Project
tab, select
Modules
to display the list of available modules.
Monitor
Controls the user’s entry into the system. Refer to
Monitor
for further information.
Admin
Allows the administrator to set up new projects, controlling which users have access to which databases, administer projects, including change management and setting AVEVA fonts. Refer to
Administrator
Draw
Produces fully annotated scale drawings showing selected parts of the design model created in DESIGN. Refer to
DRAW
Isodraft
Controls the production of isometric drawings. Refer to
ISODRAFT
Spool
SPOOL is the pipework spooling module. It allows the user to split the pipework design into logical sections (spools) ready for fabrication. Refer to
Pipework Design
Paragon
Provides a set of intuitive windows and menus allowing complete administration of the Catalogue and Properties. Refer to
Catalogues and Specifications
Specon
Used by the administrator to create or modify the component specifications within the catalogue database. Specifications define the suitability of catalogue components for particular types of use. Refer to
Lexicon
Allows the system administrator complete control of the administration of the Dictionary (DICT) database of a project. Refer to
LEXICON
Propcon
Used by the administrator to create or modify the properties database, which holds details of those properties of the components and materials which may be needed for stress analysis or safety auditing of all or part of a design. Refer to
When the user changes to a different module a
Confirm
window is displayed, to confirm the module change. Select
Yes
to enter the selected module or
No
to cancel.
