DRAW Administrator Guide
Defaults : Set System Defaults
System defaults are set using the System Defaults window. On the Admin tab, in the Setting group, click System Defaults to display the System Defaults window.
After modifying the System Defaults window the administrator can save the updated settings.
After modifying the System Defaults window the administrator can save the updated setting to a new filename. Click to display a Save Defaults window which allows the administrator to navigate to a location and name the file.
Displays the Default Load Errors window which lists any loading errors.
Click Cancel to close the Default Load Errors window. The administrator is returned to the System Defaults window.
A confirm window displays asking the administrator to OK re-loading of the default files. Click Yes to load the files.
The Master Project Defaults and Local Project Defaults sections of the window display the default settings of the pointers to the DRAW Libraries. To change any of these, either type the new element name into the text box, or navigate to the required element and click CE. The text to the right of CE displays the type of element required for each Library.
The library reference defaults also display on the User Defaults window. On the Tools tab, in the Defaults group, click User Defaults. The User Defaults window is initialised with the settings from the System Defaults window after the defaults have been loaded from file. Subsequent changes made on the User Defaults window override, but do not change the settings on the System Defaults window, allowing a user some flexibility in the use of available libraries during drawing production.
To open the Layer Purpose Definitions window, click Layer Purpose Definitions on the System Defaults window.
All layers have a PURP attribute which is set to a four character keyword which identifies the purpose for which that layer is intended to be used. Layer purposes cannot be duplicated under any one owning View. The Layer Purpose box on the window allows the administrator to specify the purpose as a three-character string (the fourth character is added automatically when setting PURP so that multiple layers of a given type can be created under a single View).
The Setup File box is used to specify the macro file that is executed to set the layer attributes after a layer has been created. Default macro files are supplied with the product. For example, DRA-GEN-DEFLAY defines the default attribute values for layers which allows users to create layer annotations to a common standard.
The Attribute Group check boxes, Dim, Note, Text, Lab and Symb allow the administrator to specify which attribute types display on the Layer Attributes window. The combination which applies to each of the currently defined layers is indicated by the + (selected) and - (unselected) codes in the scrollable list. To change these, turn the attributes on and off as required.
To associate a layer default with a setup file, click Insert.
Click OK to set the layer defaults or Cancel to discard any changes and close the Layer Purpose Definitions window. The administrator is returned to the System Defaults window.
To open the Layer Creation Definitions window, click Layer Creation Definitions on the System Defaults window.
Select the Purpose from the list, and change the Layer Purpose and Suffix as required.
Click OK to set the layer creation definitions or Cancel to discard any changes and close the Layer Creation Definitions window. The administrator is returned to the System Defaults window.
To open the Layer Purpose Filtering window, click Layer Purpose Filtering on the System Defaults window.
The window defines what Layers are visible in the Layer Note drop-down list on the appropriate application menu bar.
Click OK to define the settings or Cancel to discard any changes and close the Layer Purpose Filtering window. The administrator is returned to the System Defaults window.
To open the Sheet Defaults window, click Sheet Sizes on the System Defaults window.
The Sheet Defaults window allows the administrator to define the dimensions and a reference description for up to 15 standard sheet sizes.
Click OK to define the sheet sizes and descriptions or Cancel to discard any changes and close the Sheet Defaults window. The administrator is returned to the System Defaults window.
To open the Name Convention window, click Naming Conventions on the System Defaults window.
Click OK to define the naming conventions or Cancel to discard any changes and close the Name Convention window. The administrator is returned to the System Defaults window.
