DRAW Administrator Guide
Defaults
When the user enters DRAW in graphical mode, the macro %PMLUI%/DRA/ADMIN/START calls the user-defined setup macro %DFLTS%/DRA-SETUP which, among other actions, points to the location of the main DRAW defaults file, DRA-GEN-SYSTEM. The environment variable AVEVA_DESIGN_DFLTS is set to the folder where the defaults file is stored.
Pointers to the Libraries from which the different aspects of DRAW’s drawing functions obtain their standard data, for example:
Definitions of name delimiters; that is, the characters used to separate the component parts of an element’s name.
Definitions of naming conventions; that is, the characters used to prefix the component name of given element types.
Definitions of sheet sizes; that is, their width, height and description.
Definitions for LAYE elements under VIEWs for use by ADP; defined in terms of their purpose and associated attribute groups.
