The Auto Naming On/Off check box is not applicable to ABA.
Select the Infill radio button to use numbers made available by deleting elements. The number used for a new element is the lowest available.
Select the Append radio button to add all new elements to the end of the numbering scheme.
The Auto-Numbering Rules window allows the administrator to define how ABA creates the drawing number for a particular element rule. The functionality of the
Auto-Numbering Rules window is similar to the
Naming Rules window. The
Naming Rules window is explained. Refer to
Naming for further information. The
Naming Rules window differs from the
Auto-Numbering window in that it allows the administrator to define auto-naming rules.
The Define Rules window allows the administrator to define which elements are selected for a particular rule. Auto-numbering works by going through each element rule to collect the relevant drawings, and then applies the associated numbering rule to those drawings.
Select from the Location drop-down list to specify the location where the element rules file is stored
Input the name of the number rule in the Name field. The name must be identical to the numbering name in the
Defined list of the window.
Input the type of elements to search for in the Types field. For example, DRWG selects drawings.
Input a rule in the Rule field to set another selection rule for the elements to be acted upon.
Click Apply to define the element rules or
Cancel to discard any changes and close the
Define Rules window. The administrator is returned to the
Auto-Numbering Rules window.
The format of the number created is made up from a combination of text and returned values from functions supplied with the ABA user interface. The function !!abaAutoNumber(‘discipline’) returns the necessary part of the number/name to the auto-naming activity, this reply is based on the
Function attribute set by the option field in the
ABA Template Drawing window.
Each choice of the DRWG function has a TKPARA attribute that matches the requirement, for example Administration returns the result
A. The user tasks are stored in the Task Library PROJ/ABA/TASK (TSKLB), ABA_Autonumber (TASK) area as TKPARA elements.
