Labelled General Defaults For Area Based ADP Use, which defines the information covered in the ABA defaults window. Refer to ABA Defaults for further information.
Labelled Permitted View Scales, which defines all scales available to users. Scales can be removed from the list using any text editor to restrict those available to the user.
Labelled Symbol Templates, which defines the names of the symbols used by the supplied tasks.
Labelled Auto Number Task, which defines the autonumber system used by the supplied tasks.
Labelled Imperial Paper Sizes, which defines the paper sizes available to the user.
Labelled Metric Paper Sizes, which defines the paper sizes available to the user.
Select from the drop-down list to display the Area ADP File Browser window. The functionality of the Area ADP File Browser window is explained. Refer to File Browser for further information.
Select from the drop-down list to discard any changes and close the ABA Defaults window.
Click Defaults File to display the Area ADP File Browser window. The functionality of the Area ADP File Browser window is explained. Refer to File Browser for further information.
Click Load to load the default settings from the defaults file.
Allows the administrator to automatically create the administrative hierarchy specified in the ABA Defaults window.
To create the hierarchy specified in the ABA Defaults window, click
![]() Click Apply to create the hierarchy or Cancel to discard any changes and close the Create Aba Hierarchy window. The administrator is returned to the ABA Defaults window.
When a hierarchy is created, initial SYMBol elements are created. If the structure exists, Create Hierarchy displays
Click Browse to specify an alternative setup batch file.
