To apply the view based method, on the ABA Template View window, select the
Keyplan radio button and then click
Keyplan Area to display the
Select Keyplan Area window.
The Select Keyplan Area window lists all area projects that have been setup using the
Area Definition window. Refer to
Create and Modify Areas for further information.
Select the Use Area Limits radio button to use the selected area for the keyplan and set the view scale so that the limits box for the area fits into the view frame for the keyplan.
Select the Auto Limits radio button for a view scale to be automatically calculated so that the contents of the drawlist for the keyplan view fit into the view frame.
Click Apply to confirm the keyplan area settings or
Cancel to discard any changes and close the
Select Keyplan Area window. The administrator is returned to the
ABA Template View window.
On the ABA Template View window, add the user task Hatch_Keyplan to the
Selected window. Refer to
Create and Modify Template View for further information.
Click OK to set the hatching and frame styles or
/Hatch_Keyplan window. The administrator is returned to
On the ABA Template View window, add the user task /*Keyplan_View to the
Selected list. Refer to
The /*Keyplan_View window allows the administrator to modify the Keyplan position and scale options.
Input values in the Position X and
Y fields to specify the location of the bottom left corner of the Overlay sheet to fit onto the drawing template.
Click Apply to modify the Keyplan View settings or
/*Keyplan_View window.
The Add Hatched Areas to an Overlay window is used to create a representation of each of the areas in the 3D model. It allows the administrator to automatically create a set of boxes with shading to represent each area.
Make sure Name has been set to the correct overlay. If not, click
CE and navigate to the required overlay.
Set the Frame colour and style and Hatch Pattern colour and style for the hatching layers in the Select Hatching Pens part of the window.
Select Hatching Pens has similar functionality to the
Pens tab of the
Library Attributes window. Refer to
Create Library for further information.
The Select Text Attributes part of the window allows the administrator to modify the text properties for the hatching layers.
Input a value for the position of the text in the Position X and
Y fields. Alternatively, click
Cursor to identify the position of the text on the drawing canvas. The
Point Construction Option Form displays. Refer to
Define View Frame with Cursor for further information.
Select from the Colour drop-down list to define the colour for the text. Alternatively, click
Pick to display the
Pick a Colour window. Refer to
Colour for further information.
Select from the Font drop-down list to define a font for the text.
Input a value in the Height field to define the height of the text.
Select a direction from the Direction drop-down list to define the Keyplan View Direction. The hashed areas are built orthogonal to the selected View direction.
Each layer represents a particular area of the 3D model as defined in the Area Definition window. When the drawing is processed with this keyplan applied, the only visible keyplan layer is the area for which the drawing is using.
Click Apply to modify the properties for the hatching layers or
Add Hatched Areas to an Overlay window.
On the ABA Template Sheet window, add the task *Keyplan_View to the
Create ABA Template Sheet for further information.
