To create a template view, on the Area tab, in the
Create group, click
Template, select
View from the drop-down list to display the
ABA Template Sheet List window. Refer to
Modify Template Sheet for further information.
The Frame drop-down menu allows the administrator to define the frame visibility, position and alignment.
To identify the currently selected template view as the current element, click CE. The administrator can select an alternative template view from the adjacent drop-down list.
To delete the current view, click Remove. A
Confirm window displays asking the administrator to OK the deletion. Click
Yes to delete the View.
Select Standard from the
Section Mode drop-down list to display all components in the View.
Select Omit Fractional Pipe Components from the
Section Mode drop-down list to remove any piping components that only partly display in the View.
Input a value in the Direction field to define the direction of the view.
For assistance in determining the scale, click the question mark. The Limit Information window displays, showing the maximum 3D distances for the chosen scale.
Select the Area radio button to produce a graphical representation of the area.
Select the Keyplan radio button to identify the View as a Keyplan View. Refer to
Create and Modify Keyplan Layers for further information.
Select the User radio button to specify the requirements for the View.
By default the Name and
Description elements in the
Tasks Available and
Selected lists are sorted alpha numerically (A-Z, 0-9). To reverse the order, click the arrow in the column header of the relevant list.
All tasks are processed in the order in which they appear in the Selected list. The administrator can modify the order. Right-click a task in the
Selected list to display the drop-down list.
To modify the currently selected task in the Selected list, click
Modify Task to display a modify window. For example, if the Draw_Gridrefs task is selected the
/*Draw_Gridrefs window displays.
Click Apply to confirm the Template View settings or
Cancel to discard any changes and close the
ABA Template View window.
Click OK to confirm the settings or
Cancel to discard any changes. The administrator is returned to the
The Add Drawing Item Lists window contains a list of all the available classifications.
By default, the Classification and
Name elements are sorted alpha numerically (A-Z, 0-9). To reverse the order, click the column header of the relevant list.
The administrator can add or remove classifications from within either the Classifications list or the
Classification List (Current View). Right-click a classification to display the drop-down list:
The administrator can select, clear and order tag rules from within either the Tag Rules list or the
Tag Rule List (Current View). Right-click a tag rule to display the drop-down list:
To order the tag rules in the Tag Rules list by description, click
List by Descriptions.
To modify a template view, on the Area tab, in the
Modify group, click
Template, select
