To create a template drawing, on the Area tab, in the
Create group, click
Template, select
Drawing from the drop-down-list to display the
ABA Template Drawing window.
The value for the Date field is automatically set to the current date.
The Drawn By field is automatically populated with the login name of the administrator. The login name is taken from the operating system, not the base product.
Select the required function from the Function drop-down list. The function of the drawing is used by the drawing selection mechanism to separate different template types during creation. It is also used by the auto-numbering functionality.
The Name field displays the name of the drawing template.
On the Size & Units tab, the administrator must specify its dimensions, either explicitly in the
Width and
Height fields, or by selecting a standard sheet size from the drop-down list.
The required Distance and
Bore units can be set by selecting an option from the drop-down lists.
Precision allows the administrator to define the precision that is required for both linear and angular data. Four values of precision can be stored, for metric (decimal) values, imperial decimal values, imperial fractional values, and angles. By default, these four values are 0, 1, 32 and 1 respectively. Angles are stored decimally, to the nearest whole number of degrees, to the nearest minute, or to the nearest second by selecting an option from the drop-down list.
The Intelligent Text tab is used to select an output format for the positional code words used to request the position of certain elements.These expand to a string providing the location expressed in the ENU (East North Up) coordinate system, or as a purely numerical output (Numbers only).
The Pens tab allows the administrator to set the line colour and style.
To select a user-defined style, click Select to display the
User-defined linear styles window. A style table is selected and then a selection is made from the list of styles. After selecting a user defined style, the check box is ticked by default. The administrator can de-select this check box to use a system defined style. The functionality of the
User-defined linear styles window is explained, refer to
User-Defined Linear Styles for further information.
If the administrator clicks Select next to
Hatch Pattern, the
User-defined fill styles window displays. The functionality of the
User-defined fill styles window is identical to the
User-defined linear styles window. Refer to
Click Reset to revert to the values applied when the
Drawing Template Attributes window was opened.
Click Apply to modify the drawing template attributes or
Cancel to discard any changes and close the
Drawing Template Attributes window. The administrator is returned to the
To create a variant of the master, click Copy as Variant. The current element is changed to the variant and is only available during a modify phase.
Select the Unset radio button to specify that no Backing Sheet is used.
To select a BACK element as the Backing Sheet, select the Reference radio button and select the BACK element from the drop-down list.
To select a .plt file as the Backing Sheet, Select the Filename radio button and input the path of the required file in the field.
By default the Name and
Description elements in the
Available and
Selected lists are sorted alpha numerically (A-Z, 0-9). To reverse the order, click the column header of the relevant list.
To modify the currently selected task in the Selected list, click
Modify Task to display the default modify window. For example, if the *Keyplan_View task is selected the
/*Keyplan_View window displays.
Click Apply to confirm the modifications or
Cancel to discard any changes and close the modify window. The administrator is returned to the
ABA Template Sheet window.
To modify a template drawing, on the Area tab, in the
Modify group, click
Template, select
Drawing from the drop-down list to display the
ABA Template Drawing List window.
To modify a template sheet, on the Area tab, in the
Modify group, click
Template, select
Sheet from the drop-down list to display the
ABA Template Sheet List window.
Select the template sheet to modify. By default, the Template Sheet window displays. The administrator can modify the template sheet as required. Refer to
Create Template Drawing for further information.
