The functionality of the Process Drawings Control Tasks window is explained. Refer to
Process Tasks for further information.
To modify the *Plot_Drawings task, on the Process Drawings Control Tasks window, select
*Plot_Drawings in the
Tasks Selected list and click
Modify Task to display the
/*Plot_Drawings window. The functionality of the
/*Plot_Drawings window is explained. Refer to
To modify the *Report_Labels task, on the Process Drawings Control Tasks window, select
*Report_Labels in the
/*Report_Labels window. The functionality of the
/*Report_Labels window is explained. Refer to
Report Labels for further information.
To modify the *Hyper_Plant task, on the Process Drawings Control Tasks window, select
*Hyper_Plant in the
/*Hyper_Plant window. The functionality of the
Hyper Plant for further information.
To process the view, the administrator must be at or below the keyplan overlay sheet (OVER). On the Area tab, in the
Create group, click
Keyplan Layers to display the
Add Hatched Areas to an Overlay window. The functionality of the
Add Hatched Areas to an Overlay window is explained. Refer to
Overlay Sheet Method for further information.
Produces a report as specified in Process Tasks, but in this case produces a single report for the relevant drawing.
Create a VNOTE below the template view with LVIS FALSE and under it create a RECTangle with its origin at the centre and part-named with the string ‘n_arrow’. The task looks for this rectangle and uses its position for the north arrow symbol. If the rectangle does not exist, then the symbol is placed at a default position defined as the top-left corner of the view.
!!abanewdrwgs.checkname(!namestring) where namestring is the required name.
