DRAW Administrator Guide
Area Based Automatic Drawing Production : ABA Defaults : Create and Modify Tasks
To create ABA tasks, on the Area tab, in the Create group, click Library, select Task from the drop-down list to display the ABA Task Definition window.
The File menu item has the options;
The Task Types part of the window allows the administrator to select a task from one of the four Task Type areas, View, Drawing, Process or Naming. Click the appropriate Task Type, all of the available tasks of that type display in the Tasks list.
The Tasks Definition part of the window allows the administrator to input a name, description and function.
The Task Parameters part of the window allows the administrator to modify task parameters.
Alternatively, select Add from the drop-down list in the lower part of Task Parameters.
To modify an existing parameter, select it in the Parameter list, change the Description and Value as required and click Replace.
Alternatively, select Replace from the drop-down list in the lower part of Task Parameters.
To remove a parameter, select it in the Parameter list and click Remove. A Confirm window displays asking the administrator to OK the deletion. Click Yes to delete the parameter.
Alternatively, select Remove from the drop-down list in the lower part of Task Parameters.
By default the Name and Description elements in the Tasks list are sorted alpha numerically (A-Z, 0-9). To reverse the order, click the column header of the relevant list.
If, on exit from the window, changes have been made but not saved, a Question window displays asking the administrator to OK the modifications. Click Yes to save any changes.
