To create a classification, on the Area tab, in the
Create group, click
Library, select
Classification from the drop-down list to display the
ABA Classification Definition window.
Input a name for the classification in the Name field and a description in the
Description field.
Input the required criteria in the Criteria field. To modify/replace or remove a criteria select the desired criteria from the
Criteria List. The criteria may be of two different types.
Select the required Criteria Type which determines the check on input criteria but depends on the type:
Select the Type of rule from the drop-down list, either
Add or
Remove.
Select the Action required from the drop-down list.
To remove the highlighted Criteria or Classification from the list, click Remove. A
Confirm window displays asking the administrator to OK the deletion. Click
Yes to delete the area.
