To create a Label Library (LALB), navigate to the Library (LIBY) level in the hierarchy and then on the Admin tab, in the
Libraries group, click
Label, select
Label from the drop-down list to display the
Create LALB window.
The administrator must specify the label library dimensions, either explicitly in the Width and
Height fields, or by selecting a standard sheet size from the drop-down list.
Click Apply to create the label library or
Reset to revert to the values applied when the
Label Library window was opened.
Click Cancel to discard any changes and close the
Label Library window.
To select a user-defined style, click Select to display, the
User-defined styles window. A style table is selected and then a selection is made from the list of styles. After selecting a user defined style the check box displays a tick. The administrator can de-select this check box to use a system defined style. The functionality of the
User-defined linear styles window is explained. Refer to
User-Defined Linear Styles for further information.
If the administrator clicks Select next to
Hatch Pattern Colour and Style, the
User-defined fill styles window displays. The functionality of the
User-defined fill styles window is identical to the
User-defined linear styles window. Refer to
Click Apply to define the label library attributes or
Label Library Attributes window was opened.
Symbol Library Attributes window. The administrator is returned to the
