DRAW Administrator Guide
Label Library
Label Library
Label Libraries (LALB) contain the Symbol Templates (SYTM) and Text Templates (TXTM) from which users can create symbolic (SLAB) or general (GLAB) labels, respectively. Each SYTM may comprise any combination of 2D primitives, text primitives (TEXP) and existing symbol instances (SYMB). Each TXTM holds specific or intelligent (#-coded) text in its BTEX attribute.
The DEPT Master_Libraries, supplied as part of the standard product, contains a REGI named DRA/MAS/LABELS, which contains LIBYs holding different types of label templates, which the administrator can adapt as required.
