Cable Design User Guide
Cableway Branch : Split Cableway Branches : Split at Point
If the cableway branch is to be split at a point, click Pick Point. The user is prompted to Pick on the segment which the branch should be split: in the 3D view. Once selected the split point is labelled in the 3D view, and the Point Definition part of then Split Cableway Branch window, is populated with the coordinates of the split point. If required, select one or all of the Lock boxes to fix the co-ordinate along the axes.
Align - aligns with the segment
Distance from segment start - the distance from the start of the segment field is also populated.
Move offset - Enter a value in the box and use the right or left arrow to respectively increase or decrease the Distance from segment start by that value.
Select Auto Name check box to apply the autonaming rules, the software automatically creates a new name for the element.
Click Split, the cableway branch is split at the point picked by the user and the split is also displayed in the Model Explorer:
