Cable Design User Guide
Cableway Branch : Create Cableway Branch : Check Connections
If the user needs to check cableway branch connections, select Check Connections from the Branch Tasks window, to display the Cableway Branch Connections window.
If no connection errors are found, green ticks will be displayed in the Cableway Branch Connections form. A message Connections correct at this point is also displayed on the form.
If connection errors are found, red balls will be displayed in the Cableway Branch Connection form. A message Error in connections at this point is also displayed on the form. The connection errors will also be highlighted in red in the 3D view.
