The Route Attachments Points Create Tasks window is a dual purpose window, which allows the
Creation of a new route attachment point or the
Modification of an existing route attachment point. For more information on the Modification of an existing route node, refer to
Modify Cableway Branch.
The Positioning part of the
Route Node Create Tasks window allows the user to define the position of the route node on the Cableway Branch.
The user can select a reference point from the drop-down menu (the Offset Distance is automatically populated) or select
Pick where the user will be prompted to
Pick on the segment which RNODE should be placed.
Input an offset distance in the Offset Distance box or select
Pick to define position (Snap) Snap.
Click to select the Mark Route Points check box to display the route point labels on the 3D view.
To display associated cables, click List Associated Cables to display the
List of Cables window, listing all the associated cables.
To create a route attachment point, click Create Route Attachment Point. The new route attachment point is a created and displayed the Model Explorer. The position of the created routed attachment point on the cableway branch is shown in the 3D view. The
Route Attachment Points Create Tasks window resets, clearing all entries so that more route attachment points can be created.
