The Define Path / Route Tasks window allows the user to create route points and position these points on a cableway branch. A route point is a reference point inserted at a defined position on the cableway branch and provides a reference for routing the branch and for adding cable tray material. To display the
Define Path/Route Tasks window, click
Define Path / Route from the
Branch Tasks window.
The Define Path / Route Task window is a dual purpose window, which allows the
Creation of a new route point or the
Modification of an existing route point. For more information on the Modification of an existing route point, refer to
Modify Cableway Branch.
The Route Position Point part of the
Define Path / Route Task window allows the user to position a route position explicitly by the input of coordinates, by the selection of a position in the
3D view or by copying the position of the previous or next route point.
To pick a position on the cableway branch in the 3D view, from the
Route Point Position part of the
Define Path / Route Task window, select
Pick Position, the user will be prompted to
Pick to define position (Snap) Snap:
To copy the position of the previous route point, from the Route Point Position part of the
Copy Previous, the position of the previous route point is copied.
To copy the position of the next route point, from the Route Point Position part of the
Copy Next, the position of the next route point is copied.
All of the created route points are displayed in the Select Route Point part of the
Define Path / Route Tasks window. Click to highlight a route point which displays the position in the
3D view.
To create route point, click Create Route Point. The new route point is created and displayed in the Model Explorer and displayed in the
Define Path / Route Task window.
