Administrator
Creating the Main Admin Elements
Multiple Databases (MDBs)
: Modifying MDBs
Modifying MDBs
The attributes of MDBs can be modified using a form very similar to the
Create
form. To display the
Modify
form, select the element you want to change in the
Admin elements
form and then either:
click
Modify
on the
Admin elements
form, to display the
Modify
window,
or
select
Modify
from the
Create/Modify
option button on the
Create
form, if it is displayed, and the mode will change to
Modify
You can change the Name, Description
the databases in the MDB and which databases are current or deferred.
