There can be a performance issue with large lists of databases. However this can be improved using the Rebuild Lists On/Off toggle. If this toggle is switched Off then the lists are not rebuilt each time a database is moved; only when using the Apply or the Now button. The default, however, is On. The picking order of databases is relevant, where databases will be added or exchanged in accordance with the pick order.
