If you have created a DB Set, you can add it to an MDB in one operation. When the Create MDB form is displayed, move the cursor into one of the scrolling list areas, and click the right-hand mouse button. A pop-up menu will appear: choose
Select a Set of DBs and select the DB Set you want from the small form listing DB Sets available. Then add the Set using the arrow button as normal.
