Administrator User Guide
Creating the Main Admin Elements : Databases : Modifying Database Attributes
The attributes of databases can be modified using a form very similar to the Create form. To display the Modify form, select the element you want to change in the Admin elements form and then either:
click Modify on the Admin elements form, to display the Modify Database window,
select Modify from the Create/Modify option on the Create window, if it is displayed, and the mode will change to Modify.
You can change the Name, Description, Access Mode and Area Number of a database, and whether or not it is a Controlled database.
The Database Type, DB Number and File Number cannot be changed.
