Administrator User Guide
Modules : Setting the DABACON Buffer Size
If the module definition does not include a buffer size, the default buffer size of 5,120,000 words (20MB) is used. The maximum is size is 51,200,000 words (200MB). The modmac macro sets the buffer size for all modules (except the Global daemon) to 12,800,000 words (50MB); you are advised to leave it at this.
BUFFER integer(where integer is the required buffer size in words)
EDIT MODULE moduleid BUFFER integer
where an existing module definition is being edited. integer is the number of words to be reserved for the buffer.
