Administrator User Guide
Modules
The modules are set up in the supplied product, and you will not normally need to create or edit module definitions in order to run AVEVA E3Dâ„¢. The only part of the definition that you may wish to change is the initialisation macro (imacro), which is run on entry to the module. The initialisation macro typically contains module-specific commands to set up the screen display, including loading application macros.
