Administrator
Import and Export Utilities
Spreadsheet Data Format
: Spreadsheet Structure
Although the import utility is flexible and allows customisation of the spreadsheet, there is a convention that needs to be followed for the data to be valid.
The first column (column A in a sheet) of every row that contains data (except for comment lines) must contain a keyword. All keywords are case sensitive.
Keyword
Data Type
TEAM
Team
USER
User
AUTHUSER
Authenticated User
DATABASE
Database
COPYFOREIGN
Foreign Copy
FOREIGN
Foreign Include
EXTRACT
Extract
WORKEXTRACT
Working Extract
MDB
MDB
ACR
ACR
ACRGROUP
ACR Group
SCOPE
Scope
ROLE
Role
PEROP
Perop
A row can also be used as a comment row. If that is the case then first populated cell in the row needs to begin with hash character (#), it does not need to be a cell in column A in the Excel sheet.
If a row does not begin with a keyword and is not a comment line then it is invalid and the Import operation will not be successful.
The following table lists the cells of a
Team
row:
Column
Values
A
Keyword
TEAM
B
Name
Name of the Team consisting only of letters (A-Z). Lowercase will be automatically changed to uppercase.
C
Description
Description of the Team.
The following table lists the cells of a User row:
Column
Values
A
Keyword
USER
B
Name
Name of the User. Avoid the use of Spaces and the following characters '$', '*', '/', '@', '|'.
C
Description
D
Security
Security setting for the User. Valid values are: 'General', 'Restricted', 'Free'.
E
Password
A password with a maximum of 15 characters plus 1 optional slash at the beginning. The slash is added automatically if not present.
F
Access Rights
The list of ACRs and ACR Groups assigned to this User. The list consists of names delimited with a space. The list may be empty.
G
Teams
The list of Teams to which the User belongs. The list consists of team names delimited with a space.
The following table lists the cells of an
Authenticated User
row:
Column
Values
A
Keyword
AUTHUSER
B
Login name
Name of the NT user.
C
Default user
Name of a Default User.
D
Other users
Users valid for this login name. The list should consist of user names delimited with a space.
Database
row:
Column
Values
A
Keyword
DATABASE
B
Owning team
Name of Team owning the Database.
C
Name
Name of the Database.
D
Description
Description of the Database.
E
Type
Type of Database. Must be one of: DESI, PADD, CATA, PROP, DICT, ISOD, SCHE, MANU, NSEQ.
F
Claim Mode
Determines access mode and claim mode:
EXPLICIT, IMPLICIT - for multiwrite databases
OVERWRITE - for overwrite databases
UPDATE - for update databases
G
Number
Database number. Leave blank for default. Databases with numbers between 7001 - 10000 and 250001 - 255000 are reserved for AVEVA therefore they are allowed but there will be a warning message during the import.
Foreign Copy
row:
Column
Values
A
Keyword
COPYFOREIGN
B
Foreign Project
A three letter project code of the foreign project from which the database should be copied.
C
Foreign Name
Full name of the database (including team name) from the foreign project to copy.
D
Foreign User
Name of a FREE user from the foreign project. If left blank it will be asked for interactively during import along with a password.
E
Foreign Password
Password for the FREE user specified in the previous cell. It is considered only if Foreign User is specified. If user is not specified then a password and username must be input during import.
F
Target Owning Team
Name of team in which the copy should be created.
G
Target Name
Name of the database being the newly created copy.
Foreign Include
row:
Column
Values
A
Keyword
FOREIGN
B
Foreign Project
A three letter project code of the foreign project from which the database should be included.
C
Foreign Name
Full name of the database (including team name) from the foreign project to include.
D
Foreign User
E
Foreign Password
Password for the FREE user specified in the previous cell. It is considered only if Foreign User is specified. If user is not specified then the password and username must be input during import.
Extract
row:
Column
Values
A
Keyword
EXTRACT
B
Owning Team
Name of team owning the Extract.
C
Name
Name of the Extract.
D
Description
Description of the Extract.
E
Parent
Name of Database or Extract being the parent of this Extract. Only MULTIWRITE databases can be extract parents.
F
Claim Mode
Specify EXPLICIT or IMPLICIT depending on claim mode of the extract.
G
Variant
Set to "Yes" for variant extracts. Set to "No" or leave blank for normal extracts.
Working Extract
row:
Column
Values
A
Keyword
WORKEXTRACT
B
Owning User
Name of the User that owns the Working Extract.
C
Description
Description of the Working Extract.
D
Parent
Name of Database or Extract being the parent of this Working Extract. Only MULTIWRITE databases can be extract parents.
E
Claim Mode
F
Variant
Names for Working Extracts are generated automatically and do not need to be stored in an exported spreadsheet or imported for that reason.
MDB
row:
Column
Values
A
Keyword
MDB
B
Name
Name of the MDB.
C
Description
Description of the MDB.
D
Databases
List of current databases for this MDB. The list should consist of full database names delimited with a space.
ACR
row:
Column
Values
A
Keyword
ACR
B
Name
Name of the ACR.
C
Description
Description of the ACR.
D
Scope
Name of the Scope assigned to this ACR.
E
Role
Name of the Role assigned to this ACR.
ACR Group
row:
Column
Values
A
Keyword
ACRGROUP
B
Name
Name of the ACR Group.
C
Description
Description of the ACR Group.
D
ACRs
The list of ACRs contained in this Group. The list should consist of ACR names delimited a white space.
Scope
row:
Column
Values
A
Keyword
SCOPE
B
Name
Name of the Scope.
C
Description
Description of the Scope.
D
Selection
A valid scope selection. This is checked by the system when importing.
Role
row:
Column
Values
A
Keyword
ROLE
B
Name
Name of the Role.
C
Description
Description of the Role.
Perop
row:
Column
Values
A
Keyword
PEROP
B
Owner
Name of the Role in which this Perop should be created.
C
Name
Name of the Perop.
D
Element types
A space delimited list of element types to which this Perop is applied.
E
Qualifying condition
A PML expression that further restricts the set of elements affected.
F
OpCreate
G
OpModify
H
OpDelete
A list of allowed and denied operations in this Perop. Keywords are:
GRANT - when operation is granted
DENY - when operation is denied
IGNORE - when operation is ignored (or you can leave the cell blank)
I
OpClaim
J
OpIssue
K
OpDrop
L
OpOutput
M
OpExport
N
OpCopy
O
Attributes
If Modify operation is allowed the list specifies attributes that can be modified.
P
Error Message
An appropriate message which will be output when a user is refused access to an element because of this Perop.
