Administrator
Import and Export Utilities
: Import Elements
Import Elements
Before importing any data make sure that
Data Access Control (DAC)
is turned off.
In the ADMIN Module select
Utilities > Import
. The
Admin Import
window will be displayed:
Specify a full path and file name of an existing Excel file to import from. Alternatively click to the right of the field to open a standard windows file browser.
Click
OK
to begin the import process. The
Importing from Excel
progress report will be displayed:
The report will indicate when the import has completed. Click
Dismiss
to close the window.
During the import process errors and warnings are marked with different colours. Errors will stop the import process, warnings will not.
If a foreign project is specified in the source Excel file then you will be prompted for its username and password during the import process.
