Administrator
Data Access Control (DAC)
ACA Interface
: Reverse Assignments
Reverse Assignments
As the name suggests, some assignments can be done the other way round. For example, a single Scope is usually assigned to a single ACR. If however, you wish to assign a number of ACRs to a single Scope, you can use the concept of reverse assignments.
To do this, select the multiple ACRs and drag-and-drop them onto the Scope. The Scope will be now assigned to all the selected ACRs.
With the reverse assignment option, it is possible to assign:
Teams to Users (e.g. to add a User to a number of Teams in single operation),
Users to ACRs or ACR Groups,
ACR Groups to ACR (e.g. to add an ACR to multiple groups at once)
ACRs to Roles or Scopes.
