Administrator User Guide
Data Access Control (DAC) : ACA Interface : Clipboard Operations
All operations that can be done with the mouse using a drag-and-drop technique can also be done on the keyboard using the windows clipboard. Select a set of nodes and choose Copy or Cut from the context menu (or press Ctrl+C or Ctrl+X combinations respectively). This copies the nodes to the clipboard. Select Paste on the destination node (or press Ctrl+V) to copy the nodes into the destination.
By selecting Copy you perform an assignment or move operation, depending on the context. By selecting Cut you perform a move operation.
