Administrator
Data Access Control (DAC)
ACA Interface
: Primary Nodes
Primary Nodes
A single database element can occur in multiple trees in different tabs. For example, a node representing a particular ACR can occur in the list of all ACRs as an ACR assigned to a User or inside an ACR Group. The original created element is designated as the Primary Node.
To show the Primary Node, right click on any node to display the context menu. Select
Go to primary node
to highlight the particular Primary Node. This will display the parent tab and tree in the active panel.
Figure 11:4.
Go to Primary Node
Figure 11:5.
Displays Primary Node
All Perop nodes are Primary as they are always displayed in the context of their parent Role.
