Administrator
Data Access Control (DAC)
ACA Interface
: Editing Data
Editing Data
To edit an attribute, double-click on the cell containing the attribute.
You can also press the Enter key to highlight and move between selections. To edit a selected cell, press Enter again. Press the Escape key to move the selection to a higher level, e.g. from a cell to a parent node.
When you edit data in a cell, the corresponding attribute in the selected database element is also modified.
Most operations can be performed with a context menu. To open the context menu, select one or more nodes and click the right mouse button. You can also perform operations on a group of nodes by selecting multiple nodes in the same grid.
