Administrator Command Reference Manual
Reconfiguration : Basic Reconfiguration : Specifying the Destination DB
The destination of reconfigured data is specified using the TO command. Some examples of the use of TO are:
Examples:
TO DB and TO DBFILE specify that the data are to be reconfigured into an existing DB, identified by its name or that of the file containing it. The destination DB must be of the same type as the source DB, and will normally be empty, but need be. For an explanation of what happens when the DB is not empty, see Copying Parts of Databases.
TO NEW specifies that a new DB is to be created to receive the reconfigured data. This is the most common option for the general compaction of DBs. It is explained further in Copies and Reconfigured Copies of DBs.
