The simplest reconfiguration involves a single DB which has no references into it from other DBs; for example, a MODEL DB which has no associated Drawing (PADD) DBs.
A simple reconfiguration requires a source and a
destination DB. When the process has been completed, the source DB will remain unchanged, and the destination DB will contain a compacted copy of the parts of the source which were specified in the
copy list.
The transfer of data takes place in two passes, the second of which is further divided into two
phases:
