Administrator Command
Stand-Alone DICE
: DICE Commands
DICE Commands
Set up the options you require using the following commands (see the appropriate command pages for details):
ERRORFILE
MODE
MAXERRORS
MAXWARNINGS
STATISTICS
You can send the reports generated by DICE to a named file using the ALPHA command.
You can check one or more DB files by using the CHECK command. In this mode, you can only refer to databases by their external filenames rather than by their internal AVEVA E3D™ DB names. Up to ten files may be specified in a single command.
The EXTERNAL command cannot be used in stand-alone mode (or by REMOTE CHECK), because only one DB file can be accessed at a time.
