Administrator Command
Stand-Alone DICE
Stand-Alone DICE
The Data Integrity Checker (DICE) can be run as a stand-alone program outside AVEVA E3D™. This may be necessary if the System database has been corrupted, and you cannot enter AVEVA E3D™.
Stand-alone DICE requires evars.bat for AVEVA E3D™ to have been run and is started up using the script named
dop
, supplied in the AVEVA_DESIGN_EXE directory.
%AVEVA_DESIGN_EXE%/dop
For a summary of the commands that you can use in DICE, see the Data Integrity Checking commands in
Command Summary
Commands to exit from DICE in stand-alone mode are:
STOP
FINISH
You can send the reports generated by DICE to a named file in your working directory using the ALPHA command.
